- Apr 18, 2005
- Greensboro, NC
why do as many people run 6o rears if 9" can be stronger, lighter and all with better clearance?
I'd say the the main reason is that a lot of people thinking along these lines are going to be running an 8 lug front and it's probably going to be a 60, then you have gearing options up to 7.17:1. If your 8 lug front is a 44 at least you have the option of 5.89:1 gear ratios. The 9" tops out at 4.86:1 gear ratios and the pinion pilot bearing area may require grinding for clearance on the lower ratios! 60 ring is bigger, pinion is bigger, housing can be shaved for clearance, most of the 60s laying around are full float. Definately not knocking the 9", it is a FINE axle, and granted you can "build" a 9", but at what cost? I'd have to disagree with the others, I'd go with the 60
I like the weight savings simply because what we do is climb. Well, most of us climb...
