90 Bronco tranny
family xj
Jacksonville NC
How do I know what transmission is in the Bronco I got? Its a 1990 Eddie Bauer edition 4wd. The guy I got it from had no idea.
The reason I ask is because I need a steering coliumn and you have 3 options for automatic transmissions
if the pan is square its a c6 if it is tapered on the back it is a aod and if it is long and has a long point on the rear it is an e40d
So I've gotta ask, why do you need a steering column? I only ask because I changed out one in my '90 Bronco before I realized how easy they are to fix, the most common problem being a broken ignition actuator rod.
I bought the actuator cause it is broken. However when I actually looked at the column someone removed the tilt mechanism and some of the wires are cut. I have no idea what they did before to make it run but I want t back to the original build. If anyone has a steerin column I am looking
