90 Bronco Transmission Question
2000F150SAS
Fuquay-Varina, NC
We have a 1990 302 with a 3 speed automatic with OverDrive. What trans. do we have or where do i look for this information?
Thanks
Thanks, it helped a little.
I now have it limited to 2, AOD or E40D. Anyone how to tell the difference and if it makes a difference with changing the fluid and filter?
John
I think you have an AOD since it's a 1990. If you have problems with it changing fluid and filter will not help. You should do that to prevent problems.
No problems, fingers crossed.
Getting ready for a beach trip so i like changing all the fluids and filters.
Unless it has been swapped it is most likely an AOD.
No swap, it's looking like a AOD. I looked again last night and the pan has 14 bolts and is square shaped with 2 corners at 45degrees.
I'm stopping today to pickup a filter and gasket so i'll find out for sure tonight.
Thanks All
