nubarbar
- Nov 10, 2011
- fort mill sc
Plans are to take complete drivetrain axle to axle, motor to transfer case from a 90 Suburban and putting it all under a 81 CJ. sense both are leaf spring, pass drop is it not possible to swap the 350 the automatic trans and transfer case from the burb to the cj ,axles to . the burbs body was trashed on a snow slide and the cj was just collecting dust {hasn't run in a long time}.motor mounts got covered with NOVAK. got the front axles I think covered with a set of full axle brackets . I'm thinking of using ranger leaf springs thinking of taking the rear leaf spring mounts off the burb and using to widen the rear of the cj. does any of this sound like it will not work. the fuel tank from the burb fits like a glove in the back of the cj using the burbs skid as a cover ( it also will fit between the wheel wells )will remove the cj's tank for clearance. do plan on moving the rear axle back some. any suggestion I will definitely make a list of things I have not thought of. this is my first REAL build and to me its huge. But nothing ventured nothing gained .
