FISHEAD
- Oct 17, 2005
- Beaufort, SC
Pulled the Tcase and had some fluid drain out of the transmission in the area of the output shaft. The transmission was at a pretty steep angle at the time. I immediately jacked it up so it was level and no more fluid. Probably no more than a couple of ounces leaked out.
Is this normal or should there be a seal at the transmission output shaft keeping the fluid in no matter the angle? Should I be concerned about losing a couple of ounces?
appericate any help..
