87XJBEAST
- Oct 26, 2008
- Raleigh NC
i have a 91 yj with the 2.5. i just rebuilt it less then 5,000 miles ago. bored out .60 over. ran strong with no engine issues, just fuel pump is going out. i went on vacation and jeep sat, my buddy drove it around evey 3 days or so and on the last drive he went to start it ran fine but he got half way up the street and it just died. as if the key was turned off and just rolled in gear.
things i know
*coil is good
*crankshaft sensor is good
*has fuel pressure not sure amount but if i push the valve in fuel comes out
*if i disconect the ecm nothing changes
*if i pull spark plugs and turn it over nothing is sprayed out of holes>>>assuming no injector pulse
*if i pull the number one wire insert a screw drive and turn it over no spark
*while turning it over if i step on the gas pedal it sounds like there is a "pop" in the intake but if i cover the intake hose it wile collapse it
*battery is good
*the was one blown 20 amp fuse in the under dash fuse box replace it and nothing
*all fuses in under hood fuse box are good
* if i switch the relays around nothing changes but fuel pump kicks on with each>>>assume all 3 relays are good
please some one help i miss my jeep...is it safe to think that my ecm is bad. any one know how to test it other then puttng my ecm in another jeep and seeing if it runs
things i know
*coil is good
*battery is good
yj 4.9.ran for 20 + mins and won't fire again.
