Streetdoc
- Aug 15, 2008
- Apple Valley, MN
A friend of mine has a 92 Jeep Cherokee WJ he's running LT285/75R16, Radial Trxus Mud Terrain, with a 4" lift,
Problem: At around 35 mph the front end begins to shake violently (wheel Hop) you can't drive through it, if you don't slow down you will wreck. We just rotated and balanced the tires,(it did it before the rotate and balance too). The front end is pretty tight (tire shop guy said the front end was good), there's a little play in the steering wheel (steering gear box). Tire shop guy said the steering stabilizer was probably bad, so we replaced it with a heavy duty aftermarket one, STILL SHAKES.
Please help!
Please help!
