xjdrew
- Apr 19, 2010
- Goldsboro, NC
So I got a 93 YJ that I bought not to long ago. It needed a new trans and the motor had a miss to it. The wire harness was pretty tore up on it also but it would start every time.
I got a good deal on a motor and tranny out of a 95 YJ with wire harness and computer (heard running also)...
So I swapped everything over including the new harness and cpu. I really didn't have to do much with the wire harness because everything was still connected on the motor all I had to do is connect it to the body harness, for the exception of the speedo and fuel pump wires that I had to rewire.
So I got to crank it and it will turn over but will not start. I got fuel pressure, I hear the fuel pump coming on. I just got no spark. Here is what I've checked so far and replaced
1. I got power at the plug of the ignition coil
2. I replaced the ignition coil
3. Checked and replaced the crankshaft sensor (had power at the plug)
4. Swapped cpu's and put the one for the 95 back on
5. Swapped distributor (new cap and rotor)
6. Checked all the ground wires
7. Checked for codes and none are present
8. Checked all the fuse's and all are good
Sorry for the long post but I'm about to go crazy with this thing
.. Any ideas?
.. Any ideas?
