93 4L60E weird issue
a_kelley
mechanical fixer
Rutherfordton
OK so first shift of the day, put it in drive, shifts to 1st. Once it shifts out of first, it won't usually shift back to first, it will start out in second gear. Manual shift to first works every time.
<40k on a rebuild by a reputable builder
New shift solenoids.
(Trans got contaminated with coolant from a blown trans cooler, flushed since then)
GM digital tech 2 can't force 1-2 solenoid on, but jumping solenoid to ground works.
I'm leaning to blown prom, tried new ecm with original PROM but same results.
What say y'all?
Ok so after further testing, 4th consistently engaged with the switch but first gear will generally only engage first time in a run cycle. Broken 1-2 shift valve sitting? Manual 1st works most of the time
