Took the jeep out yesterday to an event about 30 minutes away, did fine entire way there, but when I went to leave the jeep turned over a couple times then battery died. I had just put a new starter on two days prior and fully charged the battery as it was an old one that would die if I didn’t drive the jeep for like a month.
Trailered it home, bought a new battery, same issue, no start. Sprayed some starter fluid in it, still nothing. I figured I had a “spark” issue and since the ignition coil is fairly cheap and easy to change, I did that. Jeep turned over about 5-6 times and battery weakened and died. It seems unusual to me that a new battery would die so quick, I don’t feel like I was cranking it excessively enough to drain and kill it.
I’m going to verify spark and fuel tomorrow but is there anything else I should be looking at, in particular as to why the battery died so quickly. Or did I just kill it with the cranking?
