Yes, the 94 is a high output, Chrysler ignition and fuel injection system. The 89 uses a Renix ignition and fuel injection system, they are not compatible. You can however, put the 94 short block in the 89 and just reuse all the original Renix intake, fuel injection, wiring harness and accessories. Do some Google searches or check out Naxja, there is a ton of info on doing this type of motor swap.
