ObeseFieldMouse
- Jan 23, 2006
- Winston Salem
Truck has a 47rh transmission. When I bought the truck, I had to put a junkyard transmission in it. Few months after putting it in and making sure it was good, I bought an ultra low stall converter from RevMax in charlotte, a modified valve body, and a few other springs, pistons, and struts to go with it. When I bought the truck, it didn't have a fuel plate in it, and had a BHAF and exhaust ready to install. All I've added are gauges. I have had converter bolt issues since install. One stripped out on install, so I ran 5 for a while. Last Sept, it developed a horrendous double knock, so I retorqued the converter bolts. Another broke off in the converter, but this solved the knock. On full throttle it has a scary grindy sound from the bellhousing, so before this weekends Flatts trip, I attempted to retorque the bolts again. Two of them felt like they were going to break, so I decided to use the Powerstroke to get to the Flatts.
First question is this. Does it sound like I'm going to need a flex plate when I pull this converter out? I'll be taking it out and getting it back to RevMax for them to fix it, or replace the back half.
Second question. Does overdrive flare any for you guys at lower RPMs? Converter is a billet single disc so I dont think it's slipping, so I'm assuming the clutches in the overdrive housing are. When I pull transmission, should I plan to rebuild it, and if I do, what goodie bits should I consider putting in it?
Keep in mind, I don't intend to make any more power with the thing, I just want a reliable tow rig capable of dragging approx 12k pounds thru the mountains.
Thanks in advance!
Thanks in advance!
