a_kelley
mechanical fixer
- Jan 26, 2010
- Rutherfordton
I've got a 95 Gran Cher I'm working on and this is what it does: Push gas, it will rev a little then start missing like crazy. 4.0L Auto. New CPS, checked dist pickup coil (new installed, no change, reinstall old), checked MAP, TPS, fuel pressure(41psi, twitches with injectors), changed injectors for a spare set that worked when I pulled them, checked wires, new cap, rotor, wires, compression (all about same except one was 15lbs lower avg 160-165psi).. getting new radiator tomorrow so we can pressure check the cooling system. checked computer with known good out of my vehicle, same. code originally read 27 (fuel injector ckt failure/problem)
ideas? trying new CPS and dist cap tomorrow.. i'm baffled so far.
