95 grand cherokee
ncblazerguy88
Member
winston salem nc
im tryin to get the bolts out that hold the hub braket i guess u call it "what the rotor slides onto" the 3 12 point bolts. 2 of them are stripped.. what r ur idea's as far as gettin them out so i can replace this axle????
Those are a 12 point 13mm you could cut off the heads and and just replace the wheel bearing Whole your at it.
If its the bolt heads that stripped, I'd weld a nut on the heads and try to extract that way. If the threads in the unit hub are stripped, you shouldbe able to drill w/o removeing the knuckle/balljoints. Might want to do like goofy suggested, then get new or used hubs, thats where the threads are.
