2.5 4cyl, AX-5 Trans (shifts good), NP231 Tcase (Advance Adapters SYE)
Flat belly skid
New 1310 Drive shafts front & rear
99-04 Super Duty Dana 60 Front
-Chromo shafts with solid spicer joints
-5.38 gears
-Spartan locker
- High steer
- ECGS slugs and 35 spline outers
Trail Gear Fab 9” Rear 3.5 OD 3/8” wall housing
- New nodular 3.25 Case with billet pinion support
- 5.38 gears
- 35 spline spool with chromoly shafts
- Set 20 ends with Explorer disc brakes
40x13.5x17 Maxxis Trep Radials- pretty much new just showing some cracks due to age, maybe 100 miles17”
Trail Gear Creeper lockers 5x5.5
E350 Master cylinder with gutted prop valve, Braided stainless brake lines throughout
Front suspension is stock YJ leaf’s and spring over
Comp cut corners
Motobilt rear stretch kit with XJ rear lift springs
Motobilt Rocker Guards
Metalcloak front fenders
Trail Gear front cage tied into frame, rear stock cage tied in.
Corbeau Baja SS with adjustable sliders and harnesses.
Paint is rattle canned.
More I forgot. Title in hand. $15k OBO
Flat belly skid
-5.38 gears
-Spartan locker
- High steer
- 5.38 gears
Comp cut corners
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
www.facebook.com
