96 s10 blazer sometimes run sometimes not
mxshee
Lexington
Got a 96 s10 blazer,4.3 v6 idels fine most times, but when u put it under load it dies .Like going upp a hill just want go.Doesn't cut off just boges real bad.Any solution or ideas on this will be great.Thanks Sc:shaking:ott
check the fuel filter
My '96 killed a coil pack with similar symptoms a year ago.
Check your fuel pressure (maybe a pump out, or a clogged filter), and spark (fouled plugs or bad pack)
if you change the plugs just make sure you put the platinums back in it since its the vortec. Itll run much better.
Vortec's and copper plugs dont like eachother.
