97 - 2006 TJ front hub bearing nut size
James Fetner
Member
Chapel Hill
I have to replace the front bearing / hub on the Jeep but it's at the farm and I am going to buy the socket here. Does anyone remember what size it is? I was looking around and think it might be a 1 & 7/16 " is that right?
Thanks
Technically it is 36mm, but 1 7/16" will work.
You will also need a 12pt 13mm socket for the hub bolts.
I always use a 12pt 1/2", its a tighter fit, and seems less likely to round off. But 1/2" or 13mm will work.
