I'm working on my '97 Chevy truck front brakes. Replacing calipers, and flex lines. Before doing all that I am bleeding all of the old dirty fluid out.
The master cylinder has two chambers, front and rear. I thought that the front brakes used the rear larger chamber in the MC. Well when I'm bleeding the fronts, the small front chamber is draining. Then I change to the left side of the truck (still front brakes) and both chambers start draining. I was keeping the fluid below the slit between the two chambers so they wouldn't mix and to keep my fluid clean and I never let it drain down too low or run out.
I still have the back brakes to go (Bleed) and will continue on here as soon as I post this.
Does the fluids draining from the separate chambers mean that I have a bad master cylinder or proportioning valve?
The reason I'm working on them is that I thought I had a bad/stuck caliper which has happened a few times before. I'm also replacing the rubber lines because I've learned that they can collapse and/or swell and hold pressure creating the one side drag. They also are deteriorating and putting black gunk in my fliud, causing even more problems.
Thanks,.
RQ
Thanks,.
RQ
