wbcarver
New Member
- Mar 29, 2005
- Danville, VA
Looking for some suggestions on sources for Dodge CTD clutch parts.
Have one in the shop now - where the line from the clutch master to the slave is cracked. The clutch hydraulics were working until this crack. So I believe the master and slave to be good.
It "appears" the only way to get this is as a complete assy from the Stealership. This part lists for around $360 - OUCH !!!!!
Is there a way to get just the line or a better source of this part?
My local AP houses list the master and slave seperately, but do NOT list the line.
Any help is appreciated.
Application is 1997 Dodge 3500
4wd 1 ton dually
CTD 5 spd.
BTW - There also appears to be a recall on the clutch Mstr cyl for this vehicle. (Just not for this reason) I am trying to verify this.
Here is a link to some info
Models Affected:
1994-1999 (BR/BE) Dodge Ram Four-Wheel Drive (4X4) (4WD) Trucks
http://dodgeram.info/tsb/recalls/828.htm
4wd 1 ton dually
CTD 5 spd.
Models Affected:
