Tradarcher
- Mar 20, 2005
- Creedmoor, NC
Got a 97 TJ with 4.0 with 143k. Oil pressure is 40-60. I have a knock that one mechanic said soundly like it was deep. The only thing I have tried so far is an oil change to 5w30 and a half can of Seafoam in the crankcase. Didn't loosen anything up. Any way to confirm it is rod knock? Where else should I look?
If I have to do a motor then what's the best option? I do want to keep this Jeep indefinitely so I am thinking crate motor as opposed to a rebuild or used. If I consider a rebuild I might want to do a stroker.
I would like to use a mechanic in the triangle area that has extensive experience doing the install that would assist in any warranty issues I might have with a crate and/or would stand behind their work if I went with the rebuild. Any recommendations?
Also, would love an auto. Doing the AW4 at the same time would be a bonus.
