'97 WRANGLER 2.5 STARTER WILL NOT ENGAGE . IHAVE CHECKED THE STARTER AND CLUTCH SWITCH AS WELL AS THE RELAY UNDER THE HOOD. ANY IDEAS WOULD BE HELPFULL
I jumped power to small wire to solenoid, I also was able to jump 12 volts to relay side of clutch safety switch to engage starter by the way I have already replaced the ignition switch
Just checking to make sure you checked your cables, battery terminals, and grounds. I know a guy who swapped a starter thinking it was bad. With new starter still the same issue, then he located a bad battery terminal.... and had two good starters
