marty79
the LS Swap Guy
- Nov 24, 2013
- Conover, NC
hello everyone, we have a 98 4 Runner 3.4L at work that I am stumped on. Misfiring on well..here it goes!
started out with cylinder 2 misfire when I first started working on it..
swapped coils with different cylinder and the misfire followed it ...to now #4 cylinder misfire.
Ok, so I put in another good known coil he has...still #4 misfire! WTH
pulled fuel rail and swapped injectors even though they are all brand new, still same result #4 missing.
swapped coil again with one that fires the other cylinder and still #4 misfire WTH
coils OHM out the same cold or hot so I know it's not the coil, Injectors all OHM out good since they are new, and plugs are new (yes they are the double ground plugs as required)
Compression on #4 cylinder is like all others 164psi
Dollar Bill on the tailpipe is "inconclusive" since at idle it stumbles so it seems to try and pull the dollar in but at the same time it doesn't so I can't rely on that test for any helpful data.
I'm really lost that it began with cylinder 2 misfire and moved to #4 misfire and now it's staying there and no matter what I do nothing changes. It's the bosses rig (LOL, I know I feel terrible). It runs and drives ok, but has that idle mis that you can feel and you can really feel it in OD with the slight throttle.
ANY AND ALL advise would be appreciated as I'm lost and apparently I'm either overlooking something or gonna have to get into the electrical stuff tomorrow. thank you for the help!!
