98 cherokee xj engine swap into a 97 grand cherokee
it should be a bolt-in swap using the ZJ motor mounts, accessories, etc...
just make sure the ignition systems are the same. 98 1/2 ish they did away with the distributor and ran an ignition coil rail. Should be a easy swap, they're the same engine.
