hscrugby
- Mar 22, 2005
- Raleigh, NC
Tested the obvious, battery, starter, and voltage at starter.
What next?
I took the starter out cleaned all the contacts, (took it to AZ for them to test) and it was fine. The battery was tested there too.
I tested the "hot" (Not sure what to call it?) cable to the starter and it's showing good voltage from the battery. I tested the relay wire and it shows good volts too. The ground seemed good, (I used a bolt into transmission for the ground to test the other wires) and the starter clicks exactly once when I turn the key. Not the low battery "click click click click click"
The jeep starts and runs fine if I push start it.
Anyone got anything else I can look for to get this thing running?
As background it started when I got back to it at the airport, and my door was open, battery was dead. Got a jump, and it ran fine since then. Yesterday the battery seemed low again, (real slow starter, like barely turned over) and I tried to jump it but no luck. I push started it and she was fine.
What next?
