98 k1500 turn over but no start? help please!!!!!
central09er
lexington, nc
heres the details its a 98 automatic 5.7L 4x4
cut off while driving down the road.... now not getting any spark...
have replaced:
-wires
-dist. cap
-rotor button
-coil
-ignition module
-camshaft position sensor
-crankshaft postion sensor
did have cel on but 2 code readers both said they could not communicate
tested obdII connector was getting power to 3 prongs, dont know if/which one was the power prong though
after turning motor over several times the cel went off?
all fuses look good
tested for power on the connector to the coil and ignition module and niether had power?
any ideas? im thinking computer maybe?
I had the same problem in my 98 and it ended being the electrical ignition switch. I had no spark also, replaced all those parts and nothing. I ended up taking off the covers where the ignition switch is and played with the two big yellow and red wires and sure enough it turned off and on when I did that. Hope this helps
