98 Ram build
Russ Hackett
Member
New bern
304.JPG 307.JPGhere i have a 1998 Dodge Ram st 5.9L currently sitting on a Dana 44 and also a Chrysler 9.25 axle. currently working on body damage. Tailgate has plenty of dings and dents so does the bed sides and the hood a good one on it too. Also the fenders on the bed were completely rusted out. This weekend we took the hand grinder and cut out as much rust as we could. I had some chrome fender flares laying around that a buddy of mine had pulled off a ram at youngs auto salvage. He tac welded them on and made them secure we then grinded down the welds filled the creases with body filler, did some sanding and then on with primer and paint hopefully within the next two weeks ill have the whole truck repainted and all the body damage gone. ill update with pictures frequently but i plan doing a custom long arm suspension set up i have dana 60 and dana 70 axles currently waiting to be regeared and repainted with por 15. and ill be doing some transmission work next week that ill take plenty of pictures as ill be going into the trans to fix a shift 3-4 solenoid and a torque converter lockout solenoid, also will be drilling a eight inch hole into one of the solenoids this seems like a common problem with the 46re trans. also will be making custom rock sliders for the truck.
here the axles started dismantling them today getting ready to paint them with some por-15 and regear them might be a couple weeks before they get regeared. 007.JPG
Heres a picture fo the fender flares that we cut out and welded the flares on and put bondo on them. better bondo job and paint is to come
428.JPG wish i had a better picture of them before you can kind of see how bad they are in the first picture of them
Also if anyone is interest in buying a dana 30 high pinion for a jeep wrangler i have one it is set up for WJ Jeep Grand Cherokee steering (bigger stronger steering)008.JPGtheres no shafts it will need them.
I want to say it has a 5" lift, but I don't remember.
Hey Russell! :flipoff2:
Yeah it's a skyjacker 5" lift with the short arms. Shocks are all
Shot pretty much.
Hey jake!! :fuck-you:
what's everyones obsession with fixing body damage? i miss my dodge, good luck on the build
i just like for it to look good i dont mind a little body damage but you gotta draw the line somewhere haha
