98 tj 2.5 not starting
GOAT
Lincolnton
I'm stumped why my tj will not start we changed intake an manifold gasket now it will turn over but not start checked computer new crank position senser an relays an fuses an all plug connections. Its getting fuel to the rail an not thru injectors an has no spark from coil or plugs any help would be great thanks
scantest for dtc's. how exactly did ya check the computer? nospark nor injector pulse sounds like no crank signal or you left an important ground off. if it has a tach see if it shows rpm when cranking. surely you didnt pinch the crank sensor wire between the head and manifold. again scantest for dtc,s
I put new crank senser on it an put computer out of friends jeep in it to check to see if that was it an have looked many times an had friends look for a ground or plug I may have forgot followed wiring harness an every plug is pluged up checked asd relay to make sure it wasn't it don't know what else to look at. Guess ill haul it to shop tomorrow hopefully it will be a simple fix
