creepytj98
Member
- Mar 25, 2010
- Clemmons, NC
i have had a motor problem for about 6 mo now and its got worse over time. its like its only fireing on 5 cyl. i have maby 1/4 power (my buddy has a 4cyl and he has a ton more power) ive changed every ingition part i could think of even changed a valve and head gasket wtith no change. it takes about 5-10 key turns to crank and i have to just barley turn it where the motor just turns over a little and i have to do it about 5 to 10 times to get it to crank. if i just hold the key it will just turn over and over without cranking. it caught on fire due to a hole in the fule tank but no damage was caused. so i put a new tank and fuel pump in it and thats when it started. at first it ran great but was i had to crank it like a do now but had full power and after a few day it started to run horrible. it also idles at about 2500 rpm. i recently pulged it into a code reader. it said at idol the motor thought it was at 80% throttle and the ignition was like 20% fast or something like that (my buddy said the ingition was set as high as it could be) im complety stuppend on this i have checked everything i can think of all my wires, compression new parts etc. the only thing i havent check is the fuel pressure but i can find anyone that has one. im gunna try and put my old fuel pump in. it came with the tank and the guy said it was new but im not to sure about that. ive read about people having a similar problem but no one has a answer. but anything helps thanks for reading
