jlshermanjr
Member
- Mar 10, 2007
- brevard nc
98 TJ tranny noise
My brother in law has a 98 TJ. Today it started making a noise in the transmission. It is making a chatter noise and is a little hard to change gears. When going down a hill with the clutch pushed in , it's worse. It's not as bad when going up hill. It also makes the chatter noise just as the clutch gets ingaged, when changing gears. The noise stops when you go to neutral,even when rolling. My thinking is the input shaft bearing has gone bad. Has anyone changed the input shaft bearing before? What is you'lls thinking?
Thanks, Johnny
BTW: 6 cyl and AX 15
Thanks, Johnny
