GotWood
Sayer of Fact
- Jan 12, 2007
- Maiden, NC
Stock 98 XJ will vapor lock if it idles for a couple minutes. Last night in drive thru it just died. I pushed it over into a parking spot, popped the hood and used the key to bleed the Schrader valve on the fuel rail. Lots of air, very little fuel. After I bled the pressure of she fired back up like nothing happened. What is causing this? It's been this way since the day I got it.
I'm going to change the fuel pump (if I keep it) as soon as the tank gets low because of the double start check valve issue these things have anyway.
