I'm happy that fixed it for you. I'll have to bookmark that myself as I knew there was a fix for p1870 and involved staking a valve but didn't know the exact procedure, as the last VB I had done cost me/customer $100 just on the VB mod, with it removed. And he wouldn't tell me what was involved but was pretty certain it involved the tcc pwm valve as he looked at it and told the other tech "see this one hasn't been done yet. (And service manual mentioned this tcc pwm valve and solenoid)
The cause of the code p1870 is the valve not properly shifting in the bore and binding according to pressure supplied by the tcc pwm solenoid hydraulic circuit. So, staking the valve fully in remediates that problem by applying full line pressure when the tcc lockup solenoid seals. Gm uses the pwm solenoid only to ease into or out of lock up. So the modification doesn't really affect that all that much as earlier 4l60e's only had lock up on/off. Yes the kit and reamer would fix it as well, but not near as cheaply or as permanently, eventually the new oversize valve would begin binding in the reconditioned bore and cause the same symptoms again, though probably after a good few miles.
