99 TJ, 2.5L, 93K. The jeep had been idling odd the last few months (driven very seldom unfortunately), sort of stumbling every once in awhile while idling. It didn't sound like a regular miss but what the hell do I know. Didn't seem to matter warm or cold. I did a tune up a couple months ago (plugs, wires, coil, dist cap, rotor) and some fresh fuel, seemed better maybe but honestly it was hard to tell, probably no real change and the symptoms were never terrible (never quit or anything and revved up just fine, power was fine for what it is - 4cyl old jeep). Fast forward to this morning. I drove about 20 miles on the freeway, no problem. Got off, had a couple stop lights so I was shifting up through the gears and I could feel it stumbling and the CEL came on, It ran real rough in 3rd gear revving up for maybe 15 seconds. I then stopped to turn back and it was not stumbling anymore the rest of the way home. However, when I stopped at intersections it was idling about 1200 or so very high (usually around 600-800?). Drove home 20 miles. Ran fine. When I got home it's running/idling normal. No more stumbling other than when it tossed the CEL on.
Pulled the Codes p0121 and p0551 (TPS and pwr steering pressure sensor). I can replace both those sensors of course but wonder if either is the problem or what might be going on here? Power steering fluid seems on the low side but defintiely not below the add line while hot.
