Ok, I've checked fuses, body ground under the dash, connections behind the cluster, and connections at the PCM just to start this off. I have no gauge readings and no CEL light, only the airbag light. Every once in a while the cluster will come back to life, when it does it gives the CEL (I have a cut up stream O2) abd the airbag light goes away. Working or not, all safety lights (gas, airbag, seat belt, and CEL) cycle on when the key is first turned as they are supposed to. Open to surjections at this point guys.
99 XJ base model, former Ohio Fire vehicle, Auto trans, yes it has some rust.
