A/C + Heat Doesnt Work - Bypass?
y2kcrawler
Lake Wylie, SC
Hey yall - so I think the fan speed selector switch for heat & a/c is broken. The valves open and it changes from hot to cold. Anyone know of a way to bypass this and just run the blower motor through a toggle switch? :Rockon:
What type of vehicle? If it is a TJ, I had that problem on mine. The selector switch that chooses what vents or defrost you want was the culprit. It has vacuum lines and a 3 wire connector on it. The electric connector acts as a "permissive" to allow the motor to energize. Mine burned up. I ended up making a pigtail for it. I've also seen on the internet that the resistor block sometimes gives out, but usually that just means you lose 1 speed first, then you may lose another speed, and then another, and then another.
