I have a 1994 yj. Lifted, 35's, 4.88's, lockers...
It's outgrown the road. I wanted a part time vehicle.
I bought a 1992 chevy extended cab for 750. Good deal, clean engine outside, few maintance problems.
305 engine, 2wd, 220,000 miles (mostly hwy miles; only 4,000 in the last 4 years).
I thought the oil pressure sensor was broken. Nope. I checked the oil and it had none. I added 3 quarts. He hadn't changed the oil in a while, a long while. It smokes on start up.
The oil is definately bad.
Can changing the oil stop the smoking?
Is ATF a good way to flush the engine?
Would anyone use the engine flush?
Any other suggestions?
The powersteering pressure hose is leaking. Is that a simple attach two ends swap?
I need to replace the radiator. Any advice? There's 4 tranny coolant lines in the radiator, will they cause a problem?
Thanks.
Thanks.
