Falko
- Mar 20, 2005
- Winston-Salem
So as I was replacing the steering box on my TJ yesterday, I got thinking about fluid selection.
I have been running ATF as my power steering fluid since I finished the Hemi swap, as that was the recommended fluid from the donor vehicle. Now I question which component should be used as the governor of fluid selection: pump or "motor"
I can only assume, having worked in a few different OEM facilities, that the Dodge system was engineered to use ATF to reduce the number of fluids in the factory and there may be no specific need to use this fluid...
I can also assume that the additive package in the ATF could have contributed to the demise of the sector shaft seal. If this is true, then the high detergent nature of the ATF most likely worked it's way through the deposits formed over the unknown mileage of the box, and that now that a reman is in place I should have no issue going forward.
What say you, internet experts?
