I am eventually going to swap in Power Wagon lockers (TracRite EL and TracRite GTL) into my 2012 Ram. Not having worked on the 9.25 and 10.5 AAM axles I tried looking for decent pictures online and there is not much out there. It does appear that they both use threaded carrier bearing adjusters like a Nissan or Toyota 3rd members and I am familiar with those so it seems like this will be a straightforward conversion (ie check backlash, disassemble, swap carrier, reassemble and set backlash/preload).
Beyond that has anyone worked on these and do you have any tips? I would love to do a Free-Spin conversion on the 9.25 but I doubt that will be in the budget anytime soon and can be done later. I think it needs a unit bearing on the passenger side so I will probably swap that out and the u-joint as well.
