ABS Wires
bcammons21
Member
Durham
I cant seem to really find the ABS wires for the front of my truck that i need to replace. Ive looked at many online sources but cant seem to really figure out if it is what im looking for.
Anyone here know what i mean or a GM tech that knows what the part number is?
I know its called an ABS wheel speed sensor.
do you mean you can't find them on the truck or you can't find them at the auto parts store?
There Should be a ABS sensor on each wheel in the front.
on a 4x4 there are teeth one the CV axle. on a 2wd the teeth shoul be on the brake rotor or hub.
Cant find them in the store.
The rings for sensor rings on the 4x4 are in the hub assembly not on the axle on the s10.
But no i cant find them in the store, figured someone would ask that though.
you might have to get them from a dealer or just go to the wrecking yard. that would be the easy way.
Just a FYI... these don't go bad very often so a used one should work fine.
Yeah mine just got cut between the UCA and the wheel, so thats why i need them.
plus i hate not havin abs in the rain.
But thanks
