barringer1
- Feb 15, 2010
- colletsville
im wanting to put a sye on my xj .. how do i need to go about this ? what would be the best brand to go with .. i have the np 231 t case. any advice at all would help thanks
Slip Yoke EliminatorDon't meen to sound dumb, kinda new to this, byt what is "sye"
The only difference in some of the kits is the rear bearing diameter and how the mainshaft is machined to accept it. I've installed both the Advance Adapters and the Rubicon Express units. Its been a good while but I believe Rubicon offers a heavy duty version with a little bigger bearing and rear adapter for the rear yoke and case. One I recall was a remachined version of the stock shaft, which made it a little weaker. I personaly like to do them on a bench where you can clean em up and inspect your work easier. You'll definately need a good set of snap ring pliers like stated above. Not the "snapring" type that has eyes made in them. This ring is more of a steel band that must be spread enough to slide over its machined resting place on the mainshaft. Screwdrivers or other shenanegans want get it done. The only tedious part is making sure the fluid recirculation pump lines up and goes into place on reassembly. Personally I would stay away from another product commonly refered to as a "hack-n-tap".
hack -n-tap?
I just did one this morning, it's fairly easy. The hardest part is dealing with the snap rings. I would recommend pulling the case, you will do better work with it on the bench instead of under the vehicle. The only special tool needed is a 9/16" ratchet wrench. Some of the nuts are impossible to get off with a regular ratchet and socket.
This helps when it comes to the snap rings
And yes I have fought them before too.
