Hey folks. Any ideas on where to source air intake plumbing fittings? I have a fuel injected chevy v-8 in my yota and would like to re-route the intake. Need some fittings to do it. Any ideas?
lowes is where i got the stuff for my 05 jeep the 3in black abs is what i used on the cheap also i spend 30 bucks and got way more than what i needed to do the job been on there since jan 06 and still running great
I have heard of white PVC melting on 3.4l toyota so I would recomend the abs also. I am using 3" 90* rubber hose from lowes to the mas then 90* rubber 3" to air box. If I had $ I would get one bent at a muffler shop
I think Orileys has a chrome pipe that can be cut to lenght and has snap on fitting (45 and 90s) w reduser and a spot for certain MAS designed for ricers but will work
If you let the CPVC (the white stuff) touch your friggin exhaust it'll melt, but as long as it's routed properly this will be fine. The ABS would also melt if it touched your exhaust.
Melting point for both CPVC and ABS is around 212F.
