wranglerrambler
- Dec 28, 2006
- oxford,nc
Like the title says... Under throttle only the defroster works. Under idle, air/vent comes through normal vents. What valve is the problem
It's definitely a vacuum loss. Not knowing the vehicle will make it tough for anyone to pinpoint. Basically, system is designed to spring to defrost mode for safety reasons. Vacuum is what pulls the doors to other positions. You may just have a small leakLike the title says... Under throttle only the defroster works. Under idle, air/vent comes through normal vents. What valve is the problem
