Air shocks and 3 links
marvilusone
Charleston, SC
I'm thinking I want my next rig on 3 links and air shocks. Does anyone have any helpful advice on which shocks to use? Has anyone ran this setup before and what where your likes and dislikes? Most likley the build will be based off of a 1981 Datsun/Nissan ext cab. I'm planning on running a GM4.3/TH350/NP205 setup with a 60 in the front and either a 60 or 70 in the rear. Tires will be 39.5 Boggers.
The 2 are independant of each other.. i.e. it doesn't matter what kind of air shock you run because you have a 3 link.
Fox and SAW are always popular, I like the SAW's because the nickel plating will look better longer.
i've had both SAW and fox on the same buggy. prefer my saw's. Easier to rebuild, better looking, bigger shaft.
