Alignment Problems
dbm4x409
c-town
I just went from 33's to 32's on my grand cherokee. If im driving under 50 it pulls right. It pulls enough that if i take my hands off the wheel it will change into the right lane. If i'm goin over 55-60 it pulls left. I also bent the bracket for a control arm on the trail the other day. Could the bent bracket be causing the alignment to be off or would it be mostly from putting new tires on and needing to get them aligned.
Any bent suspension will cause alignment issues. It isn't tires that change your alignment. You get an alignment when you get new tires so you don't wear out your new tires. You'll need to fix that bracket and then get it aligned because it will probably not come into spec with a bent bracket.
your alignment being out should not cause it to pull one way and then to the other that sounds like you may have a tires pull or loose parts on your front end
