Barnes 4wd
- Aug 6, 2007
- Etowah NC
Three Link and Four Link Suspension tabs and brackets. Durability, strength, ease of installation and quality should be at the front of your mind when building a 3 or 4 link suspension. When you have planned a trip, taken time off work, and worked countless late nights on your rockcralwer to hit the trail, the last thing you want is to have a suspension failure end your trip early (and, of course, probably at an inconvenient location). All of our bent brackets are 1/4" steel and our single tabs are 3/8" to match the strength of the bent brackets. What you will discover is the strongest 3 link and 4 link brackets that you can buy. These tabs and brackets are made to last for the life of your rock crawler because the last thing that you want is to spend time setting up your link suspension only to have to redo it. All Link Brackets are sold in pairs; keep this in mind when comparing prices. One pair of brackets replaces 4 single tabs and that makes our brackets less expensive than many other companie's tabs. However, tabs are sold individually, so you can mix and match different lengths for desired angle variations. All of our 3 link and 4 link brackets are available in three different mounting angles so that you can mount your Johnny Joints in a neutral position to maximize axle articulation. All have 1/2" holes; you can drill them bigger if needed. When shopping for brackets and tabs, be sure to also check out our great selection of rod ends, and tube inserts to get you project underway.
Axle Link Mount Pair
https://www.barnes4wd.com/Axle-Link-Mount-Bracket-Pair_p_67.html
Inner Frame Link Mount
https://www.barnes4wd.com/Inner-Frame-Link-Mount-Bracket-Pair_p_64.html
Link Tower
https://www.barnes4wd.com/Link-Tower_p_148.html
Adjustable Inner Frame Link Mount
https://www.barnes4wd.com/Adjustable-Inner-Frame-Link-Mount-Bracket-_p_65.html
Flat Bottom Link Mount Pair
https://www.barnes4wd.com/Flat-Bottom-Link-Mount-Bracket-Pair_p_164.html
Outside Frame Panhard / Trackbar Mounting Bracket
https://www.barnes4wd.com/Outside-Frame-Panhard-Trackbar-Mounting-Bracket_p_218.html
Link Tower
