rattlecanpaint
- Apr 18, 2005
- Winston Salem
So I've put two different alternators in this thing, a new voltage regulator and rewired the voltage regulator to alternator.
Original alternator died, when the B+ wire broke. I figured that was also the cause of my flickering charge and e brake warning lights. I fixed that and the lights were still on so I put in the first new alternator on in. Lights still on and charging too much voltage. (Got up to about 17 before I could shut it down). Put a new voltage regulator on it but same thing. Ran new wires from voltage regulator to alt, lights go out but now it doesn't charge at all. Put in second alternator, stil not charging. (but the lights are out.) When I put a meter across the battery terminals with the engine running I get 12.5 volts and dropping. Drops faster when I rev it up. Any ideas?
