I can't seem to find any information about this anywhere on the internet so maybe yall can help...I'm wanting to run 3/8" steel tubing for my fuel lines and remote trans cooler lines. Prefer steel for greater strength and safety. I want to use -AN fittings (nut, sleeve, barb) for the transitions between hard line and flex.
The question is can I use the much more easily found aluminum -AN fittings (instead of steel fittings) with a flared steel tubing? I would never ask this for brake line applications but for this 100 PSI and less stuff will the aluminum -AN seat and seal in a steel flare?
I understand the mixing of dis-similar metals is not preferred for corrosion, but the trans and fuel don't contain water so the corrosion betweent he two will be minimal.
Thanks for the help.
