- Mar 11, 2005
- Sanford, NC
* If you are choking on an ice cube, don't panic. Simply pour a cup of boiling water down your throat and presto. The blockage will be almost instantly removed.
* Clumsy? Avoid cutting yourself while slicing vegetables by getting someone else to hold them while you chop away.
* Avoid arguments with the Mrs. about lifting the toilet seat by simply using the sink.
* For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure in your veins. Remember to use a timer.
* A mouse trap, placed on top of your alarm clock, will prevent you from rolling over and going back to sleep after you hit the snooze button.
* If you have a bad cough, take a large dose of laxatives, then you will be afraid to cough.
* Have a bad toothache? Smash your thumb with a hammer and you will forget about the toothache.
Sometimes, we just need to remember what the rules of life really are:
You only need two tools: WD-40 and Duct Tape.
If it doesn't move and should, use the WD-40.
If it shouldn't move and does, use the duct tape.
