I have a '80 CJ7 with a 304, edelbrock performer intake and truck avenger carb, OEM ignition, replaced by previous owner. I can not get this thing dialed in.
I set the timing at 5 to 7 BTDC and the RPMs go up over 1000, idle screw all the way out. Can not get idle down to 700 rpm range.
Mixture screws by the book says set by factory, shouldn't have to touch, but if you do they should be the same, one was about 1.5 turns out and one was about 3 turns out. I tried 1 turn 1.5 turns and 2 turns, resetting timing each time. Engine wants to backfire when under a load, like when your going slow say 40 mph in 4th gear (t176) and gas it, it backfires and chokes out. Seems to do better when 2 turns out, but idle rpms were 11 to 12 hundred, and again, idle screw all the way out.
What am i doing wrong? Or better yet if there is anyone in the Apex area that can help me dial this thing in, i would appreciate it.
