Hey guys newbie to amc's does anybody know where I can get assembly procedure or instructions for assembling all the accessories on an amc 360! Thanks
Dereck
This is where I'm at. I ordered an intake so ill have that in a couple days but as far as everything else I have a general idea where it all goes but that's it
IIRC, there are differences in the brackets, depending on the year models. Early stuff is different from '80s...some slight, some major. I'd be happy to snap some pics, but mine is 100% bastard mix-matched across the board... '73 long waterpump w/ junkyard pulley, CS-144 alt, late model York mount, 2-groove crank pulley, '72 PS junk & no mech fan...
Thanks yeah I still needed it. I'm not sure the year of mine but when I bought it everything was in a 5 gal bucket. I put the money into the engine from crank to valve springs everything is new. Just need to finish putting it together.
If you need anything more specific let me know, I've had 360's in and out, up and down 4 times in the past 3 months. Having bad luck but know where and how for everything. Make sure you stud your distributor tie down instead of regular bolt and antiseize the 4 big bolts on your Water pump... you'll be glad you did it later. Oh and don't make the mistake I made with the 1st one. If its been sitting a while since you built it and primed the oil pump last, reprime the pump... rod through a block will make you puke.
