BERTIE RENEGADE
- Jul 25, 2009
Newly rebuilt 401 10 psi oil pressure @ idle, increase rpm and oil pressure drops to nothing. Initally primed oil pump with drill and shaft before starting motor got 60-70 PSI.
1.Changed to mechanical gauge...same thing
2.Removed dist. and inspected oil pump shaft (looks fine)
3.Tried to prime with drill and only 15psi.
4. Removed oil pan and checked pick up tube (looks fine)
Have not removed oil pump yet, any suggestions for things to check, with oil pump or bypass springs or otherwise?
